Thanks Slew,
Lots of finish work to do as yet.
1) Refit/trim Dashcap better.
2) Remove doorpanels, cut speakerholes (fr), dye/reglue tan panels, & refit.
3) Remove seats to fix any sagging and re-dye in Palomino.
4) Replace the door seals.
5) Remove column indicator switch assy & chemically clean copper contacts.
Re-install w/thin film of dielectric grease on all contacts
6) Have window motors rebuilt.
7) Install speakers, amplifier, and complete wiring.
8) Steam clean headliner.
9) The three toggle switchbank where the ashtray used to be, will be wired
to control:
- Turn on the A/F meter in cubbyhole under glovebox.
- Open or close the aux air device ala manual choke.
- Turn on under-dash lighting (grn) also wired to door switch.
eBay Motors: 4PC GREEN LED INTERIOR UNDERSEAT LIGHTS UNIVERSAL (item 260200192390 end time Jan-11-08 21:20:19 PST)
10) Replace the indicator needles on the speedo and tach (tach in red).
Replacement Gauges and Speedometers for Classic Car Musclecars and Vintage Automobiles
11) I recently installed Fog lamps under the front bumper, so another switch
for them as well. I am also installing relays for the H4/H1's in front.
I think that's about it except that I'll probably replace the alternator to the 164 style to handle the amperage.
