Temporarily between Hurricanes here in Louisiana...thought I needed to change pump & filter..already changed in-tank pump. Borrowed a lift, as recommended put a clamp on fuel line after unscrewing fuel cap; clamp was not enough so used vise-grips to stop fuel leakage. Removed pump & wires; new (& old) uses smaller diameter stud for +, & larger for negative wire, almost forgot to re-use rubber sleeve on old pump(vibration damper). Filter a bit easier, but again almost forgot to re-use rubber sleeve. Check for in & out markings. Took about an hour & all is well. Started right up.
Chief Bre.
Chief Bre.
