I know many people have already heard that wear additives in oils have been dramatically reduced in the past couple of years due to new EPA regulations. It is documented that people have worn down camshafts within few hundred miles who ran common name brand oils not knowing they had been changed, especially with new engine break ins. Do a web search for more info. The engines most affected by the decreases amounts of zinc and phosphorous are push rod and flat tappet engines (which category our old Alfa engined fall into). I have 3 old Fiats & Abarth that are push rod engines as well.
I have switched over to Shell Rotella t HD 15 40 after reading recommendations from many classic car and motorcycle experts. It is a very high grade oil that can be used in any gas or diesel powered vehicle. I found out today from the Shell Tech person that due to new requirements, Shell did have to reduce slightly the zinc content a few months back, but it is still .12% down from .14%, which is about what classic oils had in them. By contrast, many modern oils do not have even half of that anymore, even many of the expensive synthetics. Rotella comes in gallon containers and cost about $12 gallon at Walmart and Kragens . I highly recommend it.
So be carefull what oil you run in your Alfa, especially if you are breaking in a new engine.
