you rock the car to get the chain tensioner spring to extend the tensioner. the spring isnt strong enough to pull the chain slack from between the cams or cams and engine by itsself.
I usually use a large screwdriver to pry the tensioner out, then tighten and check tension on chain. a coupla weekends ago, my tensioner backed off, must have been too loose on the bolt, and made a lot of noise. if you rock the car make sure the chain dosnt skip a tooth on any sprockets.
cliff
cliff
