1 - 2 of 2 Posts
Hi all, I purchased a heavy duty centre support from Alfaholics and got a local garage to change it form me. I have refitted the drive shaft and it seems that the support is under undue stress. Should the support have only been partially pressed onto the shaft or similar. I do not know if there was a stopper or similar or they pressed it on all the way and it should only got on a certain distance from the end. All I know is I do not think it will last long once I do the front nuts on the drive shaft. when the drive shafts sits without any pressure the shaft is probably 10-15mm from seating properly. Obviously I got do up the nut to pull it into place but a little concerned about doing that.
Any help advice much appreciated.
Chris
1 - 2 of 2 Posts
