1 - 17 of 17 Posts
Supporting Vendor
We are proud to announce our new Corsa cat-back exhaust system for the Giulia and Giulia Ti models (including Q4 AWD models). We have been developing and testing this system with Magnaflow for a number of months. This exhaust will be available exclusively through Centerline.
https://centerlinealfa.com/catalog/corsa-exhaust-giulia
Video Link:
In my opinion, this system is what these cars should have been delivered with! To that end, we have gone to great lengths to ensure an OEM level of fit and finish. The OEM exhaust is very quiet, but also has a number of "awkward" bends and kinks. The Corsa system gives a deep, throaty exhaust note, yet is smooth and quiet while cruising. It is a full 3" diameter mandrel-bent system that is designed to be free flowing, working great on 100% stock vehicles yet having enough flow to accommodate highly modified vehicles as well.
Please note: we followed the naming convention we use on our 4C exhaust and called this the "Corsa" system because it does not have a rear resonator. However, it is not anywhere near as loud or raw as the 4C Corsa system. Everyone has different tastes in exhaust, but we feel this system is perfect for anyone who wants a nice, sporty sounding exhaust - whether it is on a daily driver or weekend toy.
We are taking pre-orders for this system at $995.00 including free shipping in the continental USA. This is $200 less than list price. This is a pre-order only, we are not asking for pre-payment and you will not be charged until the system ships to you.
Reactions: JMody
Looks nice and sounds nice Joe. Sounds a lot like the Fiat Abarth and Alfa 4C, just like I expected it to.
I was under my Ti the other day looking at things to find that the stock pipe was flattened to clear the rear suspension. It almost half the diameter for almost three feet. (shivers)
The exhaust is awesome. The Giulia now sounds like an Alfa should. It really opens up when you paddle shift.
Gas flow isn't much affected by the shape of the tubing. Changes in the area of the pipe cross section will create wave reflections (which are exploited in designing both intakes and exhausts). However, changes in section shape without reducing or increasing cross sectional area will have no effect on gas flow. Even bends have very little effect on flow efficiency. Mandrel bending exhaust pipes is a complete waste of money. Gas flow is not much affected by those ripples from ordinary bending methods.
Virtually 100% of any perceived improvement obtained by fitting an aftermarket exhaust system to a new car will come from increased noise. Mufflers work by restricting gas flow in order to remove some of the energy from the wave forms. You cannot reduce noise without some restriction in the flow. Conversely, nowadays, the factory engineers do not leave anything on the table when designing intake and exhausts.
If you like the added noise the aftermarket systems deliver then fine but don't delude yourself into thinking you're getting free extra power, not possible.
Supporting Vendor
This was definitely not our experience at all with the 4C exhaust systems - they gave great gains in power which were evident in normal driving and proven on a dyno. We find that direct-injected, turbo 4-cylinder engines really respond well to being opened up right after the cats.
I expect the Giulia system will be similar. Alfa went to great lengths with the Giulia to make the stock system very quiet to appeal to the non-traditional Alfa buyer. So you are correct that the main selling point of the system is acoustics.
We should have dyno tests completed shortly for this system and will update everyone with the results.
Wow - Are you speaking from experience? So do you have one of those Canadian Stebro exhaust systems on your 1991 164 (with 230,000 Km) that incorporates those special "changes in section shape without reducing or increasing cross sectional area" and "those ripples from ordinary bending methods" ?
I'm sure the Dyno numbers will show a 4 to 6 hp increase but I don't care. The seat of my pants Dyno says wow. The exhaust note is awesome. Perception is evrything.
Reactions: shakingthrough
Standard pipe bending collapses the tubing making the cross-section smaller. This constricts the flow of the hot gasses. Mandrel bending forces the tube to remain at a constant diameter allowing for a constant cross-section which reduces the bottle-necking of gasses.
Yes, one costs more than the other. One also offers more overall performance than the other. It's not a linear equation, at some point you will spend more money than the power gains your getting. An intake and exhaust system will only net you 10 or 15 HP. Perhaps that same money could be used more effectively elsewhere. But, as point out earlier, you won't get the music, which play a big part in the sensation of speed and power.
Also, a better flowing intake and exhaust is a necessary setup to support the expected big power gain from an ECU chip.
Ultimately, it all depends on what you want and what you're willing to do to get it.
When I got my TI a couple weeks ago, my only real complaint was the exhaust. I just ordered Centerline's Corsa system. It should arrive on Tuesday, hoping to have it installed by the end of the week.
I'm really looking forward to hearing it.
Got it installed.
I think it's one of the best upgrades you can do for a 2.0 car. Sounds great, really wakes the car up. The system is very well made, and fit perfectly.
I didn't buy it expecting any horsepower gains, and honestly, I can't tell if there is a difference.
When you get on it, it's pleasantly raspy with a few "pops" here and there, and at highway cruise speeds, there is absolutely no droning.
Agreed, the factory exhaust is silent. I gotsta have it. My question is does it affect the warranty? Also, do the air induction and the OBD setups affect the warranty?
This will definitly increase the impression of horsepower !!
Supporting Vendor
Discussion Starter #14
The question of warranty on new cars is one that comes up often.
The answer is of course "it depends..."
First - many dealerships actually install our exhausts, intakes, and tunes for customers, while other dealerships are 100% against aftermarket parts. So, I would suggest feeling out the service department at your local dealership, since they are the ones you are going to have a long-term relationship with.
Second - a warranty isn't a black and white thing. A dealership cannot "Void" your entire warranty because they find an aftermarket part. What they would have to do, according to the Magnussen-Moss act, is prove the aftermarket part caused a failure before they could deny warranty coverage on that failure. More generally, what often happens is they would blame an aftermarket mod for a failure on a particular system, even if they don't have proof. For example, a tuned ECU, which increases boost, could be used as reasonable grounds to deny coverage for a turbo failure, but would not be reasonable grounds to deny coverage on a brake, suspension, or transmission issue.
Third - and this is just my opinion based on interactions with dealerships across the country; I don't get the impression that Alfa is going out looking to void warranty coverage, or that aftermarket performance parts have caused major warranty issues.
Out of the common aftermarket mods, the ECU tunes are most likely to cause warranty issues - however with the tunes for the 2.0T engine you are easily able to re-flash your stock ECU programming back to the car before taking it in to the dealership. Unfortunately, the QV is a whole other level of complexity so this isn't an option.
Thanks Joe. As usual your honesty and upfrontness gives us solid information to make our decisions. The exhaust is definitely on my list.
Just had mine installed. Just for grins I asked the dealer in Shreveport how much to install and made him aware of the two hours it normally takes. My grin quickly changed to a look of complete astonishment when he said $450.00!! Holy cow, give me a brake! I took it to Big Kahunas Automotive, yeah I know it's a quirky name but I knew the guy who started it and he was one of the good guys and they still have the best rep in town. Anyway the install was $156.00 and they knocked it right out while I waited. I had him drive it past the shop (4 lane 65mph limit) and it sounded awesome even without the crack back from the waste gate bleeding between shifts. Great addition, no doubt about it although I should have gotten the ex lg gloves.
break not brake
Reactions: Biscione
1 - 17 of 17 Posts
