Trying to remove the center pod to lube the speedo cable, and it seems to be hung up on something along the bottom. Is there something else besides the 4 screws holding it in place?
Quick followup. When reinstalling, the speedo cable was quite loose. It's basically being held on by that thin wire attached to the collar on the instrument cluster. Is there a trick to getting that plastic sleeve on the cable to "lock" to the cluster? I pushed and twisted to no avail...
OK, no worries thenI suspect it doesn't take much to retain. Haven't worked on one of these myself, but this is not a precision joint. As long as the cable is roughly there, it will work. The spedo cable on my truck is held in by grease and dirt to the transmission.Works fine.
