I've also heard that a K&N filter is a noticeable improvement over the stock filter box, yielding better throttle response a few more hp.
From my experience the K&N pod does nothing, unless you run piping upto it, it's going to suffer from heat bleed from the engine bay and defeat the purpose of having a pod. Your better off keeping the airbox and setting up the cold air intake better.
Also, spooty22, I didn't really believe my brother when he told me either, but then he provided the dyno sheets. it was something like 95kw atw or something, I don't know how they "adjust" it for a fly wheel reading, maybe they factoring in average loss over an awd system? who knows.
But it was delivering max power at 7100rpm or something, 100hp before the cut out and 400rpm higher then what a standard 16v revs out to.
And there is no room for a turbo setup in a sud. because of the limited space infront of the engine, place for intercoolers is VERY limited, and you have to start thinking about top mounting things, and you start loosing engine bay space quickly once you start doing that, and factoring in piping.
My sud engine bay is packed enough as it is, just with the 16v...
By all means though, if you had a 33 16v, they'd lend well to a turbo. Lots of room up infront of the radiator.
lenus.
