Photo 1 shows 3 carb support rods that are all about 14-1/2 in long over all. Pics 2, 3, and 4 show details.
I "think" they all are from 105 series 1750's but not sure about the variations.
2 have weld on nuts at top, one does not and it is about 1/8" longer. One, with the nuts, has a clearance detent at the bottom for the starter I think.
Can anyone add clarification as to the applications.
Also does any one know the lengths of the 1600 and 1300 versions. I guessing the 2 litre length to be the same as the 1750.
Ciao
Ken
Discussion Starter · #2 ·
More carb supports
Here are a couple of pics of 2 more supports the I hope someone can ID for me. They are about 13-1/2' long overall.
One has a much smaller bottom end (on left) than the others and no nuts. That might make its effective length center to center longer??
The other has weld on nuts.
Ciao
Ken
Another Carb mount from GTAj?
This one is,I am almost certain, from a GTAj and attaches under the Weber DCOE 45s on the single tud on the carb bottom. I'll will edit when I get a length.
Did the GTAs and/or the GTA Corsa's have a similar but longer support??
Ciao
Ken
Discussion Starter · #4 ·
any one have knowledge???
KEn
I've been thru the same ID question and found out a little.....
Was told that the one with the "notch" is for a 2.0.
The one with the small lower bush is a 101 Veloce.
The ones with the welded on nuts are for the '69- up 105/115 euro with the airbox on the carb side.
I used one of these on my 1750 and ground the nuts off !!
Randy
Reactions: kengta
Discussion Starter · #6 · (Edited)
Here's one said to be from/for 1300 (105?). 12.25 inches hole to holes. For sale here Carb support for 1300
Said to be "just shy of 13.5 over all"
Rectangle Ruler Tape measure Font Wall
Bicycle part Tool Wrench Wood Composite material
Tool Musical instrument Wood Bicycle part Hand tool
