1 - 5 of 5 Posts
Hi everyone , I am not quite sure where to post this but I'll try here , I recently restored my car and the following problem suddenly ocured , when I'm driving and I'm casing it its all good when I leave my foot of the gas I hear a really loudish rattle almost as if something is rubbing on the body , could this be an unbalenced prop shaft? I had it balenced before I installed it
Probably the exhaust is touching something. The engine "torques" as you get on and off the gas and the exhaust moves around with it. Check where the exhaust is close to the heat shield and other places.
Also check all rubber/hangers supports for exhaust. I had a rattle and found that the support near the trans support cross member was shot. Also check that all bolts are tight.
1 - 5 of 5 Posts
