1 - 15 of 15 Posts
What are you using for working on your Soider at home?
I would love a 2 post or 4 post lift, but just don't have the space and money.
Has anyone had experience with these Tilt Lifts? are they useful? from the look it seems like a good home solution to working on everything except dropping the transmission.
eBay - The UK's Online Marketplace
I just invite this guy over. Biggest problem is keeping him from shouting and waking up the neighbors.
"HULK CHANGE TIE RODS!"
"Yeah, man, I know. Keep it down, will ya?"
Discussion Starter · #4 ·
Do the floor stands give you ability to work on the suspension easily? what is the pros and cons?
The tilt stand looks really intriguing to me.
Yes, yes, plenty of options....I could dig a hole and drive over it, or I could drive up a concrete road divider.
this is really not helpimg him.. i do not know about that stand/lift if it is made of steel and you could lock it up on the lift phase.. it looks like it would be safr..
here's another model from Sweden. I have never seen one but people claim they are OK. Almost the same design. On the pics they have a Jaguar on it, so it should take a Spider too.
More pics -> Om Mekaniska billyftar hos Verktygsboden.
The MaxJax looks like a great piece of kit...wish my garage had that sorta headroom. The Swedish set-up looks interesting as well - assume you crank it up manually ? Must have an Acme screw thread, or similar...wonder if a drill could be used with a special chuck, to speed the process? Interesting thread...
just don't do it like this.
Tilt Table Car FailVideo
This is how that one you are looking at works
and this one I saw a long time ago
That last one I would think you would have battery acid all over the place.
as well as gearbox oil and break oil and motor oil leaking out all over.
How much head room do you need for the MaxJax?
Depends on the car really. I had to raise up our garage door opener by about 4" to be able to raise our mini cooper up to full height. I have had the Spider, GTV, 944 on it without any trouble.
In the lower pic you can see the spider fits under without changing the door lift. The Mini was higher.
MaxJax Portable Two Post Lifting System by Dannmar
I had to raise up our garage door opener by about 4"...
Another option is a jack shaft door opener. If you have the type of garage door spring that is wound around a horizontal rod above the door header, the opener then mounts to either side of the door instead of hanging down in the middle of the bay. Add high lift tracks (to raise the door closer to the ceiling) to maximize the vertical space.
1 - 15 of 15 Posts
