Is this a spica motor? If so the cold start solenoid could be acting up and flooding the engine. Try disconnecting the wire (tape it off to be safe).
Says it an 87 so its an L-jet. When you replaced your in tank pump, did you replace the stepped hose?Is this a spica motor? If so the cold start solenoid could be acting up and flooding the engine. Try disconnecting the wire (tape it off to be safe).
No to both. Just the pump.did you replace the fuel filter under car when you did the pump?
Hot restart issues are becoming common threads. I had one, and found that my coil wire corroded and was giving weak spark through an also fouled (but not very old) cap. Couple drives later, one of the flywheel sensors crapped out resulting in no start also. My AAV is inop and contributes some to stumbling when hot for a few seconds only occasionally.I have been driving my car 4 days a week to work for the past month. Finally got to the point where I felt it was reliable.
After work I stopped at the grocery store (hour drive). Only one mile from home. I couldn't get the car started. Turned over strong. Just wouldn't catch. Waited 10 min while I got my kids to pick me up and take me home.
I called AAA. They came in 45 min. I first tried to start it. I couldn't hear the fuel pump clearly (maybe). But after a few tries it started and it started to putter back to life. After 2-3 more tries and feathering the gas to keep it running, it ran fine. I had the tow truck follow me home. The entire time back it ran fine. I have a little bit more than a half tank of gas.
The only thing I did recently was replace the in tank pump about a month ago. Car ran but main pump was getting loud at the half tank mark. After replacing it, main pump sound is back to normal. Another symptom was hard starts when the gas was very low. But that is all fixed with the new pump.
I am a software developer by day. I say I can't fix it if it's not broke. Meaning, I have be able to reproduce the issue before I can try to fix it.
Since its running now (I will check in the morning), how do I go about troubleshooting? Something getting hot and needs cooling down? I hate those issues. This is the first time dealing with this issue.
Thoughts?
That sounds like a sensible plan. My initial thought was the fuel pump relay playing up for your issue.My plan this weekend is to start cleaning up electrical connections. Lots of electrical connections
In hindsight, I tried to start it a few times. Wouldn't that pressurize the fuel so the pump wouldn't be working? When I thought about listening for the pump maybe it was already done. That is why I said "maybe".That sounds like a sensible plan. My initial thought was the fuel pump relay playing up for your issue.
If the in tank pump is playing up I think you would hear the main pump being louder than normal as it struggles to pull the fuel through. It sounds as though you didn't hear the main pump when you had the no start?
Good question and TBH I don't know the answer. I'm sure somebody better informed than me will be along shortly, though.Wouldn't that pressurize the fuel so the pump wouldn't be working?
