1 - 2 of 2 Posts
Hi guys
With no warning the gearbox in my S3 Spider has suddenly refused to go into first gear. All other gears select fine but first is just blocked. The gearbox was reconditioned about 3 years ago and everything else is fine.
I know nothing about transmissions - can anyone tell me what to look for if I pull the box out?
Phil
Richard Jemison
trans issue
Common problem is the transmission mount has failed, and shift leaver is hitting the surround.
If you lift the transmission up and the trans goes into gear normally then you need to replace the trans mount.
If it still won`t go into gear, then the trans has to come out and be opened and the problem fixed.
1 - 2 of 2 Posts
