1 - 11 of 11 Posts
I have been doing some reading up on the so-called canister in the hidden compartment of my 1986 Spider.
In 33 years of ownership I have yet to open up this hidden compartment.
I have been going through my Spiderwebbed workshop manual, also I have the excellent L-Jetronic information from HPSI Motosports.
Also, if I do open up the compartment and take it out, any way of verifiying it is working correctly. How do you check such a charcoal canister for proper working?
Many thanks
Many thanks
1978 Spider
I believe that's a vapor canister. As long as it's not plugged and you can blow thru it, then it's probably fine.
Hi Johan,
Interesting to meet you here! Trust you are keeping well.
if it is charcoal canister (that is what I make up from the descriptions in the manual, it is filled, or should be filled with charcoal. I guess?
Jeroen
Hi Jeroen,
i few years ago i cleaned mine. As i remember i wondered the weight, i guessed it was empty. Do you have problems with the spider or are you just checking the injection system.
The canister in the compartment behind the front right wheel is full of charcoal. The vapor canister in the trunk is empty.
The plastic tank in the compartment in the truck is for vapor recovery - no charcoal.
1627917
The metal tank in the right front wheel well does probably have activated charcoal inside but the can is sealed - not easily serviced. The best you can do is make sure the hoses are intact & connected and the one way & vent valves operate properly.
1627921
Camera on front tire facing backwards:
1627919
vapor canister mounts:
1627920
canister removed:
1627918
don't know what year the changeover was made but the charcoal canister on the S4 is plastic. The metal ones could rust.
I wouldn't bother trying to "clean" it, as long as the hoses to/from it are not blocked.
Guy on utube cut one open (different car), looks like there are just a bunch of charcoal pellets
and just for fun, this is my favorite photo showing how to get at it:)
Yep, it is just an empty plastic tank. Only weighs a few ounces. Can't imagine there's really anything to go wrong with it as the only thing that goes in it is fuel vapors. I'd just leave it be .
1 - 11 of 11 Posts
