41 - 60 of 89 Posts
Discussion Starter #41
Thanks Tommo45 , if you take your time and pay close attention to all the layers of different pieces (take pictures for reference) it's not too bad , also take note of the material thicknesses if you are mating up to original metal as it does change , other than that it's pretty strait forward , good luck !
Discussion Starter #42
Got the "A" post repair piece on last night , turned out great just have to get a tool with a smaller radius to blend out the weld right in the corner where the door seal goes on .
Discussion Starter #45
Outer rocker installed , sorry forgot to take pictures of the process , basically line up the top edge of the flange that attaches to the top of the middle and inner rocker and tack in place , install door and adjust bottom edge of the outer rocker by pushing the panel up or down and clamp in place once you achieve the correct gap at the bottom of the door , remove door and weld in place . Make sure you are 100% happy with the door gap at the bottom as it is a lot of work to change this later . Again I used the method of pre-drilling the panel and spot welding in place.
Discussion Starter #46
Fitted and installed the front fender lower repair panel , takes quite a bit of patience fitting this piece to get it to line up really nice as the contour of the formed edge at the wheel opening is not quite the same as the original fender and you have to be mindful of the rear edge where it creates the door gap . I was also dealing with some previous damage to the drivers side which had been crudely hammer and dolly straightened . Took all day Sunday but turned out ok.
Discussion Starter #50
Repairing the drivers side inner fender in pieces to get the correct contour so that it tucks perfectly into the lip of the outer fender repair panel , most likely would have been easier to buy a new repair piece but who is keeping track of man hours , it is a hobby after all.
Discussion Starter #60
Just a quick comment , the lower rad support repair piece I bought (comes in 2 pieces) is pretty good quality but is going to take a little bit of work to get it to fit in nicely.
41 - 60 of 89 Posts
