I was in the trunk adjusting the trunk latch. I discovered the alarm ecu and was wondering if you could directly work off the wires from it to the aftermarket keyless entry system to easily get at the following wires (features):
doors
horn
parking lights
trunk
siren
I have used a simple keyless system on a Porsche 911 1979 and a Milano 1987
with success but the cars I worked on did not have any factory alarm installed so I just found the approriate wires and installed relays when needed.
I was originally going to find a remocon lrt-1 but it seems to be scarce.
Harv
It depends ...
Do you have a '91-'93 or a '94-'95? I'm guessing you have a '91-'93 since you mentioned remocon.
For '91-'93, the connector to the anti-theft unit (in the trunk) has these wires:
doors - yes, central lock and unlock wires (brn-wht, ppl-wrt)
horn - no
parking lights - yes
trunk - no, but the trunk opening solenoid wire should be near by
siren - yes
For '94-'95, the IR receiver unit is at the roof console. I found it is easiest to find and make all the connections under the steering wheel area.
