Want to know what fits best? Run the simple software found here: http://greend.com/carb_software.htm .
What it will show you is that you can use the 45's, but you won't gain anything over 40's because both carbs will need to use the same size chokes.
To use the 45's to advantage, you'll need higher compression ratio, bigger valves, porting, hotter cams, etc.
