Can I swap European manifolds, exhaust and intake from a 1750 to a 2L and visa versa? It looks like I can, but I need to make sure. Thank you all ahead of time. Oh, cam cover too?
Can I swap European manifolds, exhaust and intake from a 1750 to a 2L and visa versa? Oh, cam cover too?
Yup, yup, and yup.
If you had Spica on the 2L head, you will have to install shorter studs to accommodate a carburetor manifold - but the hole pattern and gasket are the same. You will need a different bypass hose for a carburetor manifold (with a drop-in thermostat) than for a Spica manifold.
Thanks Jay. That is what I thought, but didn't wnat to screw up. I've done enough of that in the past. Thanks for the stud info. The 2L is on a Euro specd with carbs now, so won't be a problem. Take care
