The two plates are for the rear of the engine, only one is needed, as is a gasket that is required in the same shape for use with this part. The round one with holes is used in attaching the flywheel to the crank. The black piece looks like it is used to cover lower portion of flywheel, attaches to the lower front of transmission, looks different then the one that are found on Nord motors. The box contains gloves, couldn’t help myself.
Thing with spring in front of gliovebox looks like restrictor used in spica bypass hose.
Its used in all the U.S. 4 cylinders.
Black cover is for the Alfetta model.
Small round ring looks to be the oil slinger that goes behind the front seal.
Short round piece. Need a better picture on it and the small round ring to be sure.
