Apparently 115 GTV stock springs sets are no longer available, or are aftermarket sets that are close to original specs. Can a set of 115 Spider springs be used in the GTV? What are the differences and trade-offs? --TIA
Bruce Sharer
Raleigh, NC
Bruce, will give you a bump on this. I would like to know also.
The information that I have seen indicates that the front springs are the same and the GTV rear springs are about 10% stiffer than the Spider springs - probably not enough to notice with old springs. So there is a possibility that the spider springs will soften and lower the rear a little.
