Can the MCs on type 101 be brassed sleeved if pitted? If so who does it? If not , where is the best source of Master Cyls and Wheel Cyls.
Many thanks
101 master cyl
Hi
Yes, the cylinder can be sleeved. White Post in Va. does it in brass and Stainless Steel Brake in NY does it in Stainless. You also have to have a near perfect piston, because the outside surface of that helps create the fluid pressure. Last I knew, someone is making new ones.
KG
