I have a set of camshafts in my '80 Spider that are stamped AR.105.270S. On the build sheet of the engine from 15 years ago they are listed as AL-5441. The lift I measure is 10.7mm (difference between lobe and 90 degrees perpendicular - not taken from a dial indicator). Is anyone familiar with these cams?
I am trying to figure an intake noise at exactly 2200 RPM, that I am thinking may be the result of cam overlap. Bearings, compression and leakdown are good, but it has quite a "knocking" noise that doesn't change with temperature, load or ignition timing, but is much more noticeable with a wide open throttle and downright loud without the airbox.
FWIW, the engine has 10.4:1 CR pistons, big valves, an Ingram HP.150 pump, backdated individual throttle intake, tube header, etc.
Steve
P.S. I just noticed that I already asked about this a while back... Sorry about that.
Steve
