I have a European 1973 2000 Berlina, with Dell'ortos, and standard cams 105 48 03 200 01.
Need to replace cams, as they are worn.
I am looking for standard performance or close to that. Nothing fancy.
I found a good used set, but the numbering is not identical. Looks like: 169 9 200.00
I searched the forum, but could not find a reference to this number.
Does anyone know these cams? Are they close enough to the standard?
It's pretty urgent :)
Richard Jemison
Base Circles on all the Alfa cams other than the Motronic intake cam(90-94) have a base circle of 1.085" so you can simply measure the height of the lobe from bottom to top. If the new cams have a lower measurement then they are not equivalent..From the 16 number I suspect they are from Alfetta series application, and will have less lift and duration than the 10548-01 cams.
