1 - 2 of 2 Posts
how do i figure out what kind of cams I have? I am digging into my newly acquired 67 duetto which i have no records for. pulled the valve cover and the cams look new...check the clearances and I am at pretty much .35 on the intakes and .50 on the exhaust. how do i determine what the cams are and the specs of the valves? thanks Paul
Alfa cams have a ten digit part number cast into them running lengthwise between two cam lobes. You may need to turn the engine in order to see them. If you can find the numbers, please post them.
1 - 2 of 2 Posts
