Hi
The only marking that I can find (installed) is "11" (not "II") stamped between the first and second lobes from the front of the engine. The 11 reads around the circumference, not down the length. Do you know what this cam is and where I can find specs?
Thank you
David
It could be a Colombo & Bariani CB47, 10.9mm lift. Not bad cams - more mid-high end than Euro cams.
Autodelta 11mm FI? same as C&B 47?
These were represented as 11mm Autodelta FI cams when I got them. I do not know what those specs are or if that is the same as C & B 47.
