After 4 years of being without an Alfa I'm back with a '74 Spider. After 2 months of work it's running pretty good.
The cam cover has a small crack just below one of the center hold-down bolts. The previous owner tried fixing it with some kind of goop but it still leaks. I was thinking of trying West System Epoxy but I doubt it would hold up to the heat.
Should I be looking for another cover (anyone got one?) or can this be fixed?
Good to be back.
Kent
what part?
some epoxyes are good for heat up to 200 degrees,,water temp is about 185-220 degrees,, not good, i have had good luck with smal crakes with alui-weld.. local harbor freight carrys it.. map gas is the best way to use it..
You can have it welded if you have a local aluminum welder. Or they're pretty cheap to replace for a good used one. They aren't worth much.
West Systems is great for marine woodwork. I would be surprised if it held up for an engine compartment.
try find a good straight s/h one, if not then weld.
This is cracked because someone was too enthusiastic tightening it up - they require very little torque to maintain a dry seal, especially if you use a quality gasket like a Viktor Reinz (german)
I probably have one lying around I'd sell you for less than the cost of welding. But shipping might put it out of economic range.
