Can you by pass the heater box by simply running a hose from the inlet on the bulkhead to the outlet.
I've removed the bottom half of the heater box (Which was simple to do and is thankfully in very good shape), cleaned it up and greased the motor but while out I though I'd take the complete unit it out for a spruce up. However I need to be able to use the car hence the question above.
Cheers.
Hook up (together) or block off the three water outlets on the manifold and water pump, and yes, you can run indefinitely that way.
