I have a 72 gtv. The buzzer (excuse the name) sounds when in reverse. I believe it is the buzzer associated with the door open and key in the ignition. It works correctly for the key but I wish it didn't buzz when in reverse.
Any ideas? In advance, thank you.
Maybe someone hooked it up to be a reverse buzzer; it didn't come from Alfa that way. I'd get underneath and see what the reverse switch wires are connected to. You might want a wiring diagram too.
I do not believe these cars came with door/key buzzers; this sounds added.
The reverse switch wires should be coming from the bellhousing, by the way. Sounds like someone hooked up to the switch on the shift tunnel by accident.
