1 - 1 of 1 Posts
Well I found some burnt wires that feed the wippers. It looks like Alfa took an 3/4" inch bundle of wires and stuck them though a 5/8" hole and then bent them 90 degrees. These are the wires that come out the right hand side of the fire wall under the Motronic harness. The rubber that went around these wires looked a little melted too.
This might be the reason for the slow drain in my Spider? Never hand any problems with the wipers.
How can I repair this or will it be OK to leave them the way they are and just cut a larger hole in the rubber so it doesn't bind them?
Murray
1 - 1 of 1 Posts
