Burman steering box - Adding oil
1926 Views 8 Replies 5 Participants Last post by  JeroenD
Dear All
How do I fill oil into a Burman steering box?
Do I need to open the small cover on the top or the full top cover?
Br
Lars
1 - 9 of 9 Posts
Now with picture
should be a little rubber fill plug on top.
Steering box leak
Hi All
Didn't see the oil filler hole on the top of the house.
Oil is in and the Steering house replacement is finished.
Looking forward to test tomorrow.
BR
Lars
does anyone know, offhand, where the rubber plug for the Burman box can be sourced? I'd like to replace mine. It is rather old & brittle.
this thread discussed a generic plug from McMaster, last few posts:
if you are adding oil.. it is leaking out.... the heat from the exhaust manifold will thin out the oil and let it leak out faster... pump in some ' red ' litium grease and it will last longer, and feel better
thanks Dom, I'll check out McMaster this weekend
These Buhrman steering box have a tendency to start leaking/weeping a bit over the years. You can replace the seal, but it is a bit of job as you have to remove the pitman arm. And if you’re unlucky you will not get it off with a puller and you need hydraulic equipment. Finally you manage to get it off, put a new seal in and a few years later, if unlucky, you have to repeat it again.
I have gone the "grease way" on my Buhrman steering box many years ago. Works a treat! Never any problems!
Jeroen
1 - 9 of 9 Posts
