I am not sure if I messed up the bottom seal on my Burman Steering box. I removed an O ring seal and metal retainer. The new seal ordered from Centerline is larger, 40mm, and doesn't fit. I started to try and remove what looks like a metal insert and what I thought was the remainder of the old seal. After chipping it a bit I realized it was not coming out.
Should I continue to try and remove the metal rim to get the 40mm seal in or try to find a new O ring and hope I didn't ruin the rim?
Any suggestions and any suggestions on where to find a new O ring?
Attached photo of the bottom with the O ring out.
