So I took apart my Burman box this past weekend. There were 7 oval shims and 4 square ones and only 45 balls somehow. Hard to say if the box has ever been taken apart. The case looks ok - The biggest issue is upper worm gear bearing is very worn. Has anyone had this successfully machined to be smooth again?
Wood Tool Bumper Gas Musical instrument
Click here for info (start at 10:50 mark):
Reactions: brad fischer
Click here for info (start at 10:50 mark): MEDIA=youtube]ZehYGsBsDCI[/MEDIA]
Yes, but the shaft in the video just had corrosion/pitting at the lower bearing face. Cutting that area, and adding more shims, would certainly work.
NC_Alfa's shaft also has pitting at the upper bearing surface (which I guess can be machined out, as in the YouTube video). But, am I also seeing damage in the "threads"? Wouldn't machining out of threads result in widening them, which would result in play?
Discussion Starter · #6 ·
Here are some better pictures after I cleaned up the worm gear a bit more. I think the previous pictures did make it look like there was wear on the inner bearing track.
if I can find someone to grind the upper bearing surface -it seems to me that removing shims would account removed material. The worm gear itself would shift upwards that same dimension. Does that cause a problem that I am not thinking about?
Product Material property Cylinder Auto part Household hardware
Tire Hand Arm Automotive tire Wheel
Household hardware Tool Office supplies Font Auto part
