I pulled the d.side caliper and rotor since I just started hearing a metal to metal scraping/grinding noise coming from that side. In my checking to makes sure all the pieces were together this bolt/spring(?) fell out the minute I touched it. So now the bottom shoe is free swinging but still held by the springs. What is this part called and is there a broken end still stuck in the works. Can I get this part from my local foreign car parts place or do I need to order it from the usual suspects. I've also included a photo of the whole shebang to see if any of you eagle eyes see other things that are amiss and my novice eyes can't see. Thanks
what part?
mbz,bmw and Volvo use the same pin on there parking brake shoes
what part?
Any with rear disk brake,and drum type parking brakes,try pick and pull in you area,it is a common part
