Found this bad boy on my 2.5:
This is the electrical connector for the #3 injector.
The wire won't go back into the connector. Can that rubber boot be removed and the wire re-crimped in there, or does the whole thing need to be replaced?
Injector Connectors | The Knock Box
Here's a quick googled link to replacement Bosch injector plugs... can get pulled apart no problem but the crimp might be used and ruined. Ebay has these plugs cheap enough to replace.
Yes, very easy to replace. The one you have is already a replacement which is probably why the wire pulled out.
Kevin
I use the Bosch plugs with "tails" like this. I use soldered connections to splice them into the harness. I know that some people swear by crimped connections but for small wires like these, I think that solder is more reliable.
Justin,
It's John in Charlotte. I think I have a couple new Bosch style plugs that I could give you. PM me and we can connect.
JP
