I just bought a black 78 Spider from the for-sale forum, and one reader requested I start a thread on its resurrection here. So here goes. No pics yet; the seller deleted the pics he posted, but I'll get some today. Here's the prelim:
This is the original thread: http://www.alfabb.com/bb/forums/alf...pider-parts-project-car-bwa-wheels-cheap.html
The basics: complete, sad black 78 Spider, BWA wheels, bad top and interioer, OK body, been sitting in the Sacramento area unused since 1996. Original Calif car, still has its blue plates, which ended up in a tow yard and has lien sale paperwork. Seller deals with such cars, and posted it to the BB for $500. I need an engine for my 74 Berlina, and thought this might be a donor candidate, so I went last Friday to Sac to see it. My posts thus far:
After getting back from Sac on Friday: My plan is to take the good tires off the Berlina, get them mounted on the BWAs, and put those back on the Berlina. Some incentive to get the rest of the car up to the level of the wheels.
This car is in much better bodily condition than I would have expected, and it's complete. That doesn't mean it's a beauty; the top is shot, the interior is pretty so so, and the engine didn't produce great compression (80-150) when we spun it over, but I may do some more research there. It's not rusty at all, amazingly. That's the Sacramento Valley for you.
Saturday: I put in a couple hours today and got it running. Put the points back in the dual point distributor, got spark, put in some gas, found I had fuel at the injection pump. Jury-rigged a few electrical connections, and it eventually fired and ran on all four. Warm I got compression readings 160-180, not bad, so I may use this engine after all in the Berlina, which I had given up on after poor readings in Sac yesterday.
It leaks fuel at the rear hoses, and the wiring is helter skelter after prior removal of the ignition switch and some fuse-box work. I'll sort that out. The heater valve leaks water all over the interior, so I'll short-circuit the heater so as to keep water in the engine. It has an actuator, but I presume it's not giving any projection at all (I haven't checked yet) so it seems to run pretty rich. I'll swap in a good actuator. Then I'll try to drive it. It has clutch and brakes. We'll see.
Near as Lenard and I can figure, it hasn't run since 1997. This is a testament to Alfa engineering, I think, especially the Spica pump. Let it sit 14 years, put a little gas in it, and it works. And still got clutch and brakes.
Tuesday: Fixed the rear fuel hose yesterday, put in a more fitting temp ignition switch, ran the heater hose direct from the water pump to the manifold outlet to solve the heater leak. Still not getting voltage to the coil, more figuring needed at the fuse box, which has been pillaged. However, hooked things up again yesterday and it fired up. Cold-start solenoid is causing problems for the starter solenoid, so I bypassed it, thus making it a tougher to start. On starting, runs at 2500 rpm due to Spica linkage screwiness. I'll swap in a decent actuator next and set the gap and rods to get it running better. Then I'll try to drive it, fingers crossed, fire extinguisher at the ready.
