Just to eliminate the easy items, have you checked to make sure the pads are not down to the backing plates? If they're OK, it might be some grit, etc. getting in between the pads and disk, or the pads might not be held in place well, and are moving around and hitting the rough, normally unswept part of the disk. Easy enough to get the wheel off and see what's what in terms of pads, retainers, bolts tight, etc.
The handbrake's fully off, right? And the lug nuts are tight? Again, the easy items.
