kits
because the front rotors were really hot that tells me that the pistons are not retracting enough to release the pads from the rotor. I would do brake caliper kits. Pull one of the front calipers off and see if you can see any rust in or around the piston that pushes on the brake pad. When I pulled the oem calipers off my 72 after sitting for ?years they were so rusty I had to replace the calipers. what are the shape of the pads?
If it were me I would get caliper kits and see where that leaves you. If the braking isn't improved dramatically, replace the calipers.
