1 - 2 of 2 Posts
For my '84. Just basic street use - sometimes a little sporty, but I'm never going to track the car. Low dust and no squealing would be nice.
My cardisc shop manual does not show the thin sheet-metal shims some other cars use to fight squeal, are shims desirable and available for my usage?
Thank you -
David O'D
Laguna CA
Stock ATE brake pads work just fine. To keep them from squeaking, make sure you clock the raised crescent feature on the pistons properly.
1619044
You can buy a special little metal tool to help set the pistons up at 20 degrees from horizontal, or you can make your own jig out of cardboard.
1619045
The pistons are somewhat hollow, and they can be very tight in the bore, so a special pair of pliers helps to twist them around.
1619046
1619047
And put a little of that Anti-Squeak grease on the back (piston) side of the pads before installing them. That also helps keep squeaking at a minimum.
1619048
1619049
1619050
1 - 2 of 2 Posts
