I'm getting a hollow, metallic sound from the front brakes on my '74. It sounds like metal on metal (but not vey loud) like when you run the pads down to the backing. I pulled the pads, they're 80%, I cleaned and lubed everything and the noise is still there. They're ATE pads so I assume that they're OEM quality.
The noise occurs just as I come to a complete stop. It doesn't happen in reverse, nor does it happen if I do a panic stop.
Anyone out there with similar a experience to share?
Thanks, RM
Thanks, RM
