Point of Info ePer does not function well except on the specific computer that has DVD installed in/on.Go here and click on the sub-category's to view diagrams and part #'s:
http://www.lancia.co.za/eper/navi?C...INT_MODE=0&EPER_CAT=SP&WINDOW_ID=1&GUI_LANG=3
Good luck!
Sorry about that. I accessed from a Mac at work. Maybe you need to start from home page, something with the cookies or firewall settings?Point of Info ePer does not function well except on the specific computer that has DVD installed in/on.
Are any lengths for the brake lines listed in the resource you pulled these from? Mind sharing?Here are a few diagrams of brake lines without ABS and with ABS. Rear lines the same but front set up different.
Nope just long they are from front to back. I used my spares on BB2 so can't measure them.Are any lengths for the brake lines listed in the resource you pulled these from? Mind sharing?
You tell us. If they have correct metric fittings and bubble flares maybe?Ok, and 6mm absolutely necessary on all lines? Or can 4.75mm (3/16") be used? I bought 5m of 6mm but it would be nice to grab some pre-made lines at the part store if it can be used anywhere.
I got one new one from Alfa Orlando once and a long S side skirt (rocker panel) in a looooooooong box once via FedEx. They still have to bend line to get in the box.I've got used OEM good condition lines that go from proportioning valve to both rear brakes if your interested. Also have a good rear subframe as well.
