Potential booster failure
I only had one diaphram fail, but that was enough. The MC rear seal leaked into the front section of the booster. This was a Ferrari booster, I believe a Girling, but I am no longer sure. I cleaned it out and could SEE
the rubber appeared fine, no cracking, or hardening. After reassembly, about 3 months later, the pedal became hard, then harder
. The Ferrari Girling discs, weren't great to begin with. Real STOPPING was nearly impossible
. Took it apaty again to find the still soft diaphram had a crack in the bottom of it where there still was some fluid
. As this was an expensive booster replace, since that time I have always washed out the brake fluid with Brake Clean spray. Sometimes, there is rust in there too
. I don't feel you can be too careful with any brake work on valuable cars
! Good enough, may not be good enough, and the final result may be disaster
Gordon Raymond
