Brake booster vacumn check valve in top right side of brake booster which has brake master cylinder attached to it. Hidden below and rear of brake fluid reservoir.
What is your reason for needing to find it?
Follow vacumn line from back of intake plenum to it.
Is your LS a 94 or 95? The 95 has EGR valve and banjo fitting and different set up at intake than a 94 model.
Always state year and model in your posts.
Thanks Steve, it's a 94. My problem is that I thnk I pulled the hose out of the intake. I can't find it and can't figure where it goes to and where it comes from. (All this started when I changed my rear plugs). You wouldn't happen to have a picture of it would you?
The brake booster hose attaches to rear of intake plenum between where idle actuator and air flow meter attaches.
