While replacing pedal box and booster on my 71 GTV with the box and booster from later spider, I realized that the shouldred bolt that connects booster to pedal are different sizes. The one from gtv has a bolt that has longer wide part on it compared to one needed on spider (got spiders pedal box without it). Fork on spiders booster is narrower where the pedal sits.
-Does anyone have an extra bolt to sell?
-Also noticed the difference in the tip/end of the rod from booster to master cylinder. The spider one has rod that has a nut on it. Is it adjustable? Will this booster work on Ate (20mm?) master cylinder with part # 383060. Thanks ahead
Discussion Starter · #3 · (Edited)
Measured forks and there is about 2.5mm difference between them. Managed to spread it gently without messing up the alignment between left and right side bolt holes, made it work. Got one more question: never mind....
Bolt. Left side (on the pic ) goes to front / booster
