1 - 2 of 2 Posts
Question: Is there a way to replace the 90° angle piece on a brake booster WITHOUT removing the booster form the car?
I have the NOS part to replace but cannot figure out how to remove it from the booster. Picture attached to show the part I am referring to on the booster.
Thank you in advance.
start with a little WD40 on connection point to the booster so as to easily break the years of "crud build up" holding it together. Then use a wrench appropriate to size of knurled edge on plastic 90, twist gently counterclockwise. It's a 1/4 turn to relieve the pressure holding it in place. (reverse to install). hope this helps.
1 - 2 of 2 Posts
