1978 Spider 1984 Spider
I'm finding 20mm and 15mm grommets for the reservoir seals. But the listings don't provide any useful info to let me know which ones I need. Same question on the clutch MC. I'd hate to order both as a precaution.
78 Spider. But not sure if it's a 20mmor 22mm MC. The old one that came off the car was 20mm ATE. The PO installed a new unbranded one. I assume to be an ATE MC clone. The MC reservoir cap is actual ATE.
both systems are NASTY NASTY looking...going to remove and clean reservoirs...and bleed, bleed, bleed.
Discussion Starter #2
Yeah. Got lots of technical stuff with the car. I don’t think that is gonna be in there anywhere.
I rolled the dice and ordered 20m from classic alfa
I'll bet these will work:
Your parts manual should have the Ate part number for the seals. The seller of these has the Ate part number. You could just search based on that.
Clutch master reservoir threads on.
