1 - 2 of 2 Posts
Is anyone using an adjustable fuel pressure regulator on a Bosch Spider? The Spider had a good bit of headwork done before I got it, and I planning on going with the early manifolds and Magna Flow system, so I thought an adjustable regulator would be nice to get it tuned right. The same sort of work on my GTV6 resulted in lean running, and I want to get the Spider right.
Also, where is a good spot to mount the fuel pressure gauge? The only place I see is on the CSI fuel hose.
IIRC, BB member Tifosi mounted a fuel pressure guage there in his Spider. A search of the Spider section with his name in the search filter might find you a photo of it. Although, thinking on it more, I also think it was of his SDS FI system...
1 - 2 of 2 Posts
