41 - 52 of 52 Posts
yes, you can fix with epoxy. see, epoxy does not shrink like polyester, and it is an adhesive, whereas, polyester is not a very good adhesive. also, epoxy is amazingly strong, compared to a talc filled polyester, and does not absorb water like a talc based polyester. the reason boats that stay in the water eventually blister on the bottom is due to the migration of water into and through the polyester. epoxy does not do this, or rather, takes an extremely long time to allow this. i am happy to explain how to do this, but it is not rocket science. once you fix a few things around the house with it, you won't know how you survived without it. using epoxy with the correct fiberglass fabric that is strong, light, and easily conformable, will, literally, revolutionize your rapairs in many instances. areas that rust a lot (spare tire buckets in the trunk), i thought of simply molding a new bucket out of fiberglass with the identical dimensions of the original, and then it can be installed by a backyard bodyman by using the correct adhesive. no welding, and no rusting, ever again. the problem is, a lot purists want metal only, but, if you drive the car a lot, i see it as much more practical.
I have a question that hasn't been covered in this excellent thread. My S4 has a galvanized body. What's the proper procedure for bodywork over galvanized? I'm talking about repairing small dings ect. that can't be reached from the backside. I plan to eventually paint my whole car but would prefer to not take it all down to bare metal. I've been spraying lacquer for nearly 50 years on furniture and cabinets but have never done a car.
That raises another question. Are you certain the sheet metal on your S4 is galvanized? If this were the case, I think it would be a much bigger issue from a welding/sheet metal repair stand point than from a dent repair stand point. My understanding is the fumes produced from welding galvanized metal will make you sick if you breathe them.
Regarding dent repair, I defer to the experts for details but there are a lot of options. With the right tools, you can get to the back side of most of the body panels on a Spider. My personal goal is to avoid using any more than 1/8 of an inch of filler on a repair.
I'm saying that it's galvanized only because I read it in an Alfa book that I have and have seen it mentioned on a few threads in the Spider forum. Other than that, I'm not sure.
Well, I am not positive either but I doubt galvanizing was used. You asked a good question and I look forward to other responses. I have similar ding/dent issues on the '88 Spider.
I still haven't found a definitive answer about the S4's being galvanized, but if you do use Bondo, the gold or platinum variety adheres to galvanized bodies. I was planning a full repaint after I retire but an unavoidable deer running down the middle of the road bumped my time frame up a bit. Luckily (??) it hit the driver side front fender right at the wheel arch. The wheel took most of the impact, creating a shimmy at 55 (probably knocked the wheel weights off), moved the orientation of the steering wheel a bit, and increased my negative camber by 1/2 degree since my last alignment. A trip to the alignment shop fixed everything except the camber. I have adjustable upper control arms ready to be put in. Another S4 paint issue is that you need to use flexible primer for the plastic bumper skins and add a flexibilizer to the bumper skin clear coat. I also used that primer on the mirrors and cowl grill and will be using it on the rocker panel covers. All of the fender damage was easily accessible from behind which made the repair a lot easier.
I'm going with the body being galvanized. I was able to work the dents out to where there is was less than 1/16" of filler required. I left a few small spots of bare metal exposed on purpose all winter and there wasn't the slightest hint of any rust formed on them. the car was in a unheated garage with a wooden floor that was built on a hillside with plenty of air circulation underneath it.
Thanks for the update. You are probably correct regarding galvanizing. Sounds like you were able to virtually remove the dents. Excellent work. I find working the metal the last 1/4 to 1/8 inch difficult.
Very interesting, I read the whole post and agree with most all said overall, a couple of points on my giulia ss I have had to make almost the whole car, I've used a lot of gas welding and followed up with lead to the joints. I never finish in lead preferring to leave a little room for a thin coat of filler? On a previous restored car, and I still have it , I had problems with each primer not sticking to the lead? In a couple of places I have had paint lifting? The filler I use is ultima, special formulated for use on most surfaces most notably Galvanised panels. And it works ,
I aim to finish of the prep of the car with the new type of filler/primer (urathane based, as shirwin williums, mentioned earlier) I'm also about to sandblast the entire she'll and aim to use an epoxy each followed by paint and stone guard, not sure on the brand, make of each yet though , any thoughts?
41 - 52 of 52 Posts
