Both feed and return are disconnected both ends and got my new favourite brake bleeder out to ensure lines were clear.
Obviously holding vacuum like that, and pressure up to 30PSI, the return line is blocked.
Supply line holds no vacuum as expected of a clear line.
Any advice for cleaning the long length of hard line? More pressure?
Discussion Starter · #2 ·
Found It. Last hard line section to the tank that crosses the TAxle.
Coat hanger end untwist, then using the twist I can screw it into the dirt and crap and pull it back out.
Main return line seems fine. Flows well and clean.
Discussion Starter · #4 ·
Yep Metal line. Crosses the transaxle. Hard plastic line from the firewall to the filter which I'm glad isn't blocked.
Fired up for the first time just 5 min ago. Lots of revs and feels good. On to roadworthy!
