1 - 16 of 16 Posts
I've never seen any stamping like this (certainly not factory stamping -- they would have had punches with the letters "A" and "R" rather than cobbling letters together).
A replacement block, maybe, with 00559 pointing to a date (May, 1959) rather than a serial number?
Wrong font, wrong size, wrong/short sequence of numbers. Looks bogus to me without a bonafied story.
I have one stamped like this however.
Are both stamps on the same engine? That in itself seems odd to me. The R looks like a composite, a circle and some short straight stamps.
Is there anything unique about a 1300 GTA block that would otherwise show? Liner spigots in block larger due to bore/stroke? Aren't they short stroke big bore compared to earlier 1300s?
Thanks for the feedback guys, it looked goofy to me as well. Yes same block has both stampings. Standard 1300 is 74mm bore 75mm stroke vs. 78 X 67.5 for a GTA Jr. motor
Would any 00559 blocks have had the number on the exhaust side flange?
No, only on the the boss below intake.
ken
1300 GTA blocks are larger in the liner location bore in the block, 84 or 85mm rings a bell. (It's been a couple years since I've worked on one).
IF it is a 1300 GTA block, I wonder if it was a blank spare parts block & somebody has stamped the short basic 1300 GTA model number to I.D. it as not just a regular 1300.
1 - 16 of 16 Posts
