Speaking of Power Bleeders, this past weekend I replaced my clutch slave cylinder again. (Centerline part lasted 4 months with light use. Thought I'd try CA this time.)
Everything was going smoothly until I started fumbling with the bleeder valve and couldn't get it closed. Poor vision, clumsiness, working at an odd angle, and general stupidity all contributed to my goof. Next thing I know, I had let the reservoir run dry and the slave bleeder started spewing air. Great! I had basically blown all the fluid out of the entire clutch hydraulic system.
No problem. I started over and within 5-10 minutes, I had everything bled properly and no more air in the system. While bleeding, I needed to tap on the master cylinder lightly with a wrench to release the bubbles that were trapped there. Front of the car was on ramps.
Anyway, the bottom line is even with a dry system, the Motive Power Bleeder makes it pretty easy to bleed the clutch hydraulics.
